QA42A pulley
I just scored a nice, tight QA42A on the cheap and i want to put it on the 782 or the 1211. I already know i need different upper bars and a pulley but i don't know what diameter pulley i need? I tried looking it up but i must be stupid and can't find anything.
Does it have a pulley on it now? If so, what size is the PTO on those engines?
I can check the pulley diameter on my 125 and QA42 tomorrow |
Item 4 in the diagram below is what you seek. Part number is IH-78055-C2 and is still available. I don't see a diameter listed anywhere, but with the part number maybe you can do some cross referencing.
http://www.cubcadet.com/equipment/AR...0-A/0128200001 |
Pulley is the same size, but the width is different.
Tim-Outside diameter on the pulley is 4 1/2".
Thank you all for the information, now I can begin the search.
Cast iron browning BK50 ---4.75 on outside diameter.
www.Surplus center lists it for about $14.00, if you want to speed it up, go 1 tooth bigger on the drive sprocket :beerchug: |
I'm far from a pulley expert but i found this and i think it would work. It's a 1/4" smaller so it should speed the thrower up just a bit, Opinions?
http://www.surpluscenter.com/Power-T...y-1-BK45-C.axd |
Think that will work,and speed it up a tad.:beerchug:
| All times are GMT -4. The time now is 10:37 PM. |
