-   -   3225 wiring diagram (https://www.onlycubcadets.net/forum/showthread.php?t=50073)
dale c. 09-23-2017 12:17 PM
3225 wiring diagram
I'm needing a wiring diagram for my just purchased 3225 . the serial # tag is gone . the problem I'm having it will start and run for about 5 seconds then shuts off . what I 've found when I crank it over there is power going to the carb solenoid and the voltage regulator but when it starts the power is gone therefore closing the fuel solenoid and shutting the engine down . the safety switch under the seat when pushed in gives me power to where I need it but when it starts it also keeps the starter engaged . is there a diode somewhere that would keep the power from going to the starter once it's running?? if I unhook the blue solenoid wire the tractor runs fine .. it doesn't appear that anything has been hacked up by po. .........thanks for any help
Oak 09-23-2017 09:32 PM
If Roland doesn't send you one PM me your email address and I will send you one.
Yes, there are 2 diodes. One for the start circuit and one for the run.
R Bedell 09-23-2017 11:30 PM
There are two different Wiring Diagrams for the 3225, depending on the serial number range.
What is your chassis serial number..?? :Huh:
dale c. 09-24-2017 02:13 PM
roland the serial # tag is gone it does have the pto solenoid on the vacuum bellows...
R Bedell 09-24-2017 02:23 PM
OK.....Look at your Seat Switch. What are the colors that go to this switch...???
:Huh:
dale c. 09-24-2017 03:20 PM
both are red 1 has a black stripe
R Bedell 09-24-2017 03:31 PM
OK....got it. Your tractor is a 1999 model.
Check the E-mail Account as listed in your profile.
dale c. 09-24-2017 09:26 PM
thanks Roland from the looks of it the diodes are inside the blower housing
