-   -   Hot Weather Operation (https://www.onlycubcadets.net/forum/showthread.php?t=48933)
bkw3614 06-06-2017 10:59 PM
Question for all who are versed in engine operation.
I am scheduled to run my 1250 in a parade on Saturday. The predicted high for the day is 102 degrees. The parade starts at 4:00 P.M., and runs for about 2.5 miles.
The tractor has side curtains, an in-tact muffler box, and, what I believe to be, the original grill. The tractor has headlights, which may limit upper air intake. I do not have the rubber plug for the spark plug, but probably could make one. There is fresh CaseIH Akcela low ash engine oil, SAE 30 in the crank case. I use 87 octane gasoline without ethanol. Occasionally, I add an ounce of MMO and Stabil to the gas if I know it won't be used within a reasonable length of time.
Am I putting my beloved 1250 at risk by participating in this parade under these extreme conditions?
J-Mech 06-06-2017 11:10 PM
No, you are not putting it at any risk at all. It's made for that.
olds45512 06-06-2017 11:29 PM
The engine gets its​ air from the flywheel side, the flywheel has a fan built in to it that sucks in air and pushes it out the front. Having headlights won't restrict air flow.
zippy1 06-06-2017 11:55 PM
Yeah, it's an air cooled engine...
If it's moving, or standing still, as long as it's running there's airflow.:beerchug:
Have fun in the parade.:beerchug:
johncub7172 06-07-2017 12:20 AM
And to add to what Jon said, and the group, starting with the Quiet line models, the engine fly wheels were changed in many ways from all the earlier engines. One was increased cooling capacity!
ol'George 06-07-2017 08:50 AM
I would think unless you are pulling a huge float behind, up hill,no problem.
Idling along waving, and eyeballing everyone eating cool ice cream will not even make that engine break a sweat so to speak.
I'm sure you will be more uncomfortable than it comparatively speaking.:beerchug:
Enjoy your parade and pity the water cooled engines idling. :biggrin2:
SGragg 06-07-2017 10:40 AM
Do a test beforehand. Run your 1250 around your neighborhood at a slow pace for 2.5 miles in the late afternoon or early evening. See how it does. This will give you an idea what to expect...
J-Mech 06-07-2017 12:18 PM
It's not going to overheat. The operator will overheat before that tractor will.
drglinski 06-07-2017 05:56 PM
It's IH built...and it's got a Kohler engine.....(as long as there isn't a mouse nest underneath the flywheel tin etc) it's like a brick.
Enjoy the parade. Drink lots of water. :beerchug:
