-   Cub Cadet Lawn Tractor (LT) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=42)
-   -   Is it possible to put a Wards deck onto my Cub Cadet 125? (https://www.onlycubcadets.net/forum/showthread.php?t=48743)
Khalz75 05-23-2017 02:31 PM
Hey all!! Last week I bought these two beasts-- Cub Cadet 125 Hydro and a (Gilson) Montgomery Ward 16 Variable... these two machines are in excellent shape considering their age! They were very well taken care of!
Long story short, I just had double knee surgery, so the riders were meant to help me mow my way thru the summer (as my recovery isnt going too well yet) uggg
I only really made the trip to purchase the Cubby, but I couldn't pass up on the Wards machine after I seen the condition it was in! The only problem is that it doesn't run (yet) and I haven't had a chance to really look at it to see what's wrong (previous owner said it might only just need new points - but I'm not very mechanically in depth to really give any proper diagnosis)
Anyways,, the Cub Cadet runs and cuts awesome! Exactly what I was looking for until I tried to get it in the back yard... I'm an idiot and didn't even cross my mind to measure the deck width (to ensure it would fit thru the gate)!! I tried everything short of notching a 3inch nook in the fence post (the wife does not think that either one of my new tractors are very sexy,, and she would really choke me if she caught me modifying the new fence in order to fit it into the backyard!)
My question is this - does anyone know if I would beable to swap the Wards deck onto the Cub Cadet without any major mods? (Again, not too mechanical savvy here, and I would choke my own self if I screwed up or damaged either one of these beauties in the process!)
If I can't find a low cost solution, I regrettably am going to have to sell the pair :-(
Any help or direction would be very much appreciated!! Thank you in advance!!
R Bedell 05-23-2017 02:51 PM
You can IF....You have metal, cutting tools (Torch, Chop Saw, etc) Welder, & shop tools. A good understanding of metal fabrication, engineering, know where to get specialty parts, the patience of Jobe and some cash.
IF NOT, go to Plan B.
Berwil 05-23-2017 03:14 PM
I wouldn't waste time swapping decks. What size deck is on the 125? There are a few sizes that will fit. Maybe you can get lucky and trade someone even up on a smaller deck.
Bill
john hall 05-23-2017 05:17 PM
I'd get the Wards running if all it needs is a tuneup--a whole lot easier than changing the decks I can assure you. You should be able to find another Cadet deck--if a smaller one than what you have is available and will fit through the gate. Stuff like that is the first thing tractor pullers sell off. Is putting a double or wider gate not an option?
Bamafan 05-23-2017 05:36 PM
If it is a good tractor and nice cutter. I would go to Lowes and buy me a new gate the size I needed, a T-post, and a small bag of ready mix and put it in. would be cheaper than buying another deck. Assuming you have chain link fence, but if its wood same thing just different materials.
dodge trucker 05-23-2017 06:21 PM
just curious what part of Illinois are you in? There may be someone from the site that isn't that far away that might be able to help....
Khalz75 05-23-2017 06:25 PM
Thank yous!
Thank you guys for the advice, tips, and for clearing that up for me!
The mowers ive had in the past have all fit the gate because I was able to just flip up the plastic Deflector and cruise right thru No Prob... But the 125 deck is solid from side to side - no fancy bells N whistles - it's just one hellluva lil tractor, and it didn't even occur to me to measure it when I went out to make the purchase (I think because I was just so stoked to be getting a Cub in the first place - and then when I seen how great of condition this nearly 50yr old tractor was in,, alls that I was really thinking about was loading it up and getting her home)...
You guys are right,, I think that I will first try getting the Wards up and running this weekend - it's def worth a shot!
The wife has already shot down my idea to modify the fence for the sole reason of fitting the mower thru...
I know the basic stuff, but I'm not too deep into the mechanical-know-how of small engine repair - so if I strike out with the Wards,, hopefully I can find someone quick up here in IL/WI who'd be interested in a pair of machines like these !
Thanks again guys! I do appreciate the quick replies and advice!!
Khalz75 05-23-2017 06:27 PM
I am northern Illinois,, close to Lake Michigan by the Wisconsin border .. Lake Villa- it's about 10min west of Gurnee/Great America
Shotgun Clay 05-23-2017 06:38 PM
If you do use your 125 to mow, check if it needs a pto button, also grease/oil moving parts/spindles. Just my advice. Good luck!
sir_lancealot 05-23-2017 07:45 PM
Looks like you have a 42" deck on your 125. If you want to keep it, look around and see if you can find a 38" deck. Should give you the room you need to fit through your gate. Someone might even trade you for your 42".
