-   Cub Cadet Lawn Tractor (LT) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=42)
-   -   Favorite Siphon Pump? (https://www.onlycubcadets.net/forum/showthread.php?t=48669)
Paradude2017 05-17-2017 10:12 PM
Hello, folks. I have a LTX 1050 with the 310-0510 transaxle, and I'm getting ready to change the oil out of there. The fill hole is pretty small so I know a hand pump is required. I was just curious as to which ones you guys preferred, or have had good luck with.
Thanks in advance, Jeff.
:American Flag 1:
J-Mech 05-17-2017 10:34 PM
I've always had the best luck just taking the drain plug out and draining it into a pan. Seemed a lot easier than sucking it out. Do you have a drain pan?
Here's a copy of the section of the manual that deals with the hydrostat. Page number 81 deals with draining and refilling:
http://service.mtdproducts.com/Train..._ch5_hydro.pdf
Paradude2017 05-18-2017 08:41 AM
Well, shoot. Everything I've read prior to the link you provided, stated I would have to siphon it out. I will look when I get home tonight and do some verifying. Thanks for the reply.
ironman 05-18-2017 03:23 PM
What the book in the link says right smack dab in the middle of page 81.....
"NOTE:
If the transaxle does not have a drain plug:
• The fluid may be siphoned out or the transaxle
may be removed from the tractor and drained
through the fill port."
Here is a link to service manual for your hydro. Doesn't look like it has a drain plug.
http://www.hydro-gear.com/23fe04618d...s/310-0510.pdf
See page 10.
Paradude2017 05-20-2017 09:13 AM
Yeah, I end up finding that service manual you provided the link to. I also picked up a siphon pump at Tractor Supply. It ended up doing the job easily. Thanks for the insight guys. :beerchug:
Link to siphon pump...
https://www.tractorsupply.com/tsc/pr...t?cm_vc=-10005
