-   -   128 clutch (https://www.onlycubcadets.net/forum/showthread.php?t=48240)
colt54 04-19-2017 02:28 AM
128 clutch
2 Attachment(s)
Hello all
I'm about to rebuild the clutch on my 128 but have a question about the teaser spring. Do I have it right way in the mock up picture? I looked at the parts diagram and seen that it looks like I might have it backwards. The second pic is how bad the driveshaft and throw out were.
olds45512 04-19-2017 08:18 AM
Looks right to me.
vr4Legacy 04-19-2017 12:28 PM
You have it right. The parts diagram is wrong.
colt54 05-09-2017 02:39 AM
4 Attachment(s)
Hello all
I rebuilt the clutch on the 128 but now I'm lost on the adjustment. I think the clutch adjusting rod is to long it measures at 11 1/2" is that the right length ?
I was reading the manual and I need .050 between the release lever and throw out bearing,As right now I have 7/16" with the adjusting nut all the way in. Here is some pictures the last 2 show how far the pedal is in the braking zone
before the release lever comes in contact with the throw out bearing.
J-Mech 05-09-2017 02:42 AM
Did you put the bearing in backwards? I can't tell.
Where is the teaser spring and the cup it rides in? (Called a spacer in the parts book.) I can't really tell in your pics....
Something for sure isn't right.
colt54 05-09-2017 12:43 PM
2 Attachment(s)
Hello J
Here are 2 more pic's for you the teaser is inside the cup. With the pedal all the way down it starts to open. I'm using a stock I just painted it yellow.
darkminion_17 05-09-2017 01:42 PM
I am assuming you are using a cc oem throw out bearing.
Adding more washers behind the nut onto the adjusting rod will help.
