-   -   682/1282 (https://www.onlycubcadets.net/forum/showthread.php?t=48108)
Riley Henderson 04-08-2017 10:56 PM
682/1282
I got a lead on two cubs from a guy at work, a 682 and a 1282. He said to be in good shape. I was just wondering about some specifics on these machines type of engines transmissions and any things that are problematic on these or any thing I should check on it. Do these engines have iso-mounts as on the QLs that preceded them? I just put a new set on the 1200 and mowed an acre and a half today ran smooth as a singer sewing machine. Thanks for any info. I will update if a make a deal on one or both of them.
zippy1 04-08-2017 11:14 PM
Originally Posted by Riley Henderson (Post 415328)
Igot a lead on two cubs from a guy at work a 682 and a 1282 said to be in good shape iwas just wondering about some specifics on these machines type of engines transmissions and any things that are problematic on these or any thing I should check on it. Do these engines have iso-mounts as on the QLs that preceeded them I just put a new set on the 1200 and mowed an acre anda half today ran smooth as a singer sewing machine. Thanks for any info I will update if a make a deal on one or both of them.
682, http://www.tractordata.com/lawn-trac...cadet-682.html
1282, http://www.tractordata.com/lawn-trac...adet-1282.html
johncub7172 04-09-2017 01:35 AM
The model 1282 was a Cub Cadet Corporation built garden tractor that was painted red for the IH dealers. While IH began production of the 682 that started out in red paint, CCC continued the model but was returned to yellow and white colors, production ended in 1984.
I'm not sure which model 682 you have, and not certain of any specific difference in value, or collectability. Much of the designs, or thought behind IH's Quiet Line models were incorporated into this "new" series of garden tractor. These series would accept engines from Kohler, Onan, Briggs & Stratton, and I'm pretty sure a Kubota D600 was slipped into the frame a time or two.
I would try for one of these two models if I had the chance, both are great! Good luck!
J-Mech 04-09-2017 02:41 AM
They are essentially the same machines with different engines.
The 1282's engine does have rubber mounts, but not ISO mounts like a QL has. They are different and seldom if ever fail. Other than that, the only real question is do you want 17 horses or 12. If the engine in either is wore out, the 12 HP is a much cheaper repair. You can repower either with whatever you want. Like I said, they are the same with exception of the engine.
