Another interchange question
I have just gotten a hydro pump off of a newer 1864. The story is that the guy replaced it thinking it's bad and then still had the same problem as with this pump mounted. He then found his issues elsewhere. Can I use any of it on a 129 or a 1250? I'm thinking at least maybe the relief valves?
Pump is the same, but it is ported. You cannot use it in a tractor without hydraulic lift.
Can't the two ports just be plumbed together?
| All times are GMT -4. The time now is 09:25 PM. |
