-   -   782D temperature gauge not working. (https://www.onlycubcadets.net/forum/showthread.php?t=4784)
BCDSFCRET 05-31-2010 08:34 AM
The temperature gauge on my 782D is not working. I have removed the the wire on the sensor terminal on engine head and grounded it. Nothing moves.
I suspect the gauge is bad.
Brian Dan
US. Army Retired
:American Flag 1:
murphycc 05-31-2010 08:59 AM
A good sensor is about $15, I'd start there.
Scott
aagitch 05-31-2010 01:35 PM
If it's a bad gauge I'd look at getting an aftermarket gauge since the oem's are pricey.
Matt G. 05-31-2010 02:32 PM
...and doesn't have numbers on it. I'm thinking about getting a new one for mine that actually has numbers on it.
aagitch 05-31-2010 02:36 PM
Matt if you get a replacement post what one you purchased I'm trying to decide on one that would fit/look good. There's a few times I've mowed in the evening and started to run out of light so I'm also wanting one that lights up.
murphycc 05-31-2010 05:41 PM
You can get Sun brand from Summit for less than $20.
I think the mech oil pressure gauge is like $12.
Scott
aagitch 05-31-2010 06:25 PM
Would the gauge be 2in or 2 1/16?
murphycc 05-31-2010 10:13 PM
http://i154.photobucket.com/albums/s...erm/sunpro.jpg
2" I believe and lighted.
The sensor that comes with the temp gauge is weak and will break, I had to replace mine with a heavy duty from NAPA....but hey for a $18 guage.....
Scott
midyearguru 06-01-2010 10:21 AM
I'd like to replace the oil pressure idiot light on my 1872 with a gauge. Do I also need to replace the sender?
Thanks
murphycc 06-01-2010 07:25 PM
Thanks
Yes, better to go mechanical though.
Scott
