Just a few questions!
I found my Uncle's old 129 sitting in the woods! I would like to bring it back to live! It is a little rough but the engine is lose.
I now know the starter generator is working! After watching a youtube video on how to op ck it. The coil is missing so I assume it is a 12 volt coil? The starter generator is a 12 volt system but needs a voltage regulator since it is not built in correct? Is there a way to verify that the voltage regulator is working? It looking like the original or 20 years in the woods does that to them! Solenoid switch looks like a mud dauber made it a home! I am not sure if it works been 20 years! So far looks like a generator belt, transmission fan, coil, and tune-up kit only things on the shopping list right now! |
There is some discussion here that will interest you.
http://www.onlycubcadets.net/forum/s...ad.php?t=47739 Coil has to be the right kind,not one from a car. Get the engine running first then worry about the rest. |
Just didn't want a new person throwing any old 12v coil on. |
Coil must have proper OHM rating. Just internally resisted isn't enough. 3.5 or 4 ohm, IIRC.
