-   -   Adding analog tach to V-Twin (https://www.onlycubcadets.net/forum/showthread.php?t=47714)
Wageslave 03-04-2017 02:10 AM
How hard would it be to add an analog tach to my 2084? I have found a few digital tachs, but I have a picture of the older tractors with the big tachometer as the main gauge in my head and think it would look a lot more fitting.
I was thinking a diesel tach with a magnetic pickup could be retrofitted without a ton of effort, but it would be nice to know what others have done.
Thanks
Shrewcub 03-04-2017 11:35 AM
I think the diesel tach would probably be the easiest. Just curious where you would mount the sensor? I guess you could mount it in the blower housing somehow.
Just a thought. You might be able to use one of the inductive wire pickups, like the digital ones use, and an Arduino to do the math and use any tach you want.
Wageslave 03-04-2017 07:43 PM
I could mount it pretty much anywhere that it would see the flywheel magnet. After pricing them out though, the tiny tach doesn't seem too bad. At least I could mount it over the non-functioning hour meter
