1964 Cub Cadet 100
Runs, mows, shifts, stops as it should.
Strong cast iron Kohler 10 HP K241 does not smoke, valves adjusted last season, fairly new carb and glass bowl filter/petcock. Engine starts right up. Original tank was cleaned and coated with POR 15 tank sealer 38" cast iron deck with NOS blades headlights reproduction tail light brand new battery new tie rod ends and drag link ends newer front tires fairly new PTO/Generator belt new deck belt last season correct metal pan seat round fenders AND reflectors The decal on the hood says "70" but everything else says it's a 100. I believe the hood was changed at some point. I have a brand new decal set for it. So, what's it worth? |
Here in western PA that would be worth $400 to $600, you might be able to get more in your area if cubs are uncommon.
Then I did ok selling it for $750.
thanks. |
| All times are GMT -4. The time now is 03:54 AM. |
