Cub Cadet 105 (Project Thread)
Starting a little dilly-do for the 105 that was gifted to me, I'm taking a lot of pictures so it goes back together without too much head banging..:bash2: It may be useful to others who need a reference to how a section of the tractor is supposed to go together...that is if the PO's knew what they are doing.
How it looked before I started the tear down. ( I don't know if I supposed to say I'm refurbishing or restoring..? I'm not going to dropp it and add ground effects... but It may not be factory floor specs, I intend to keep the spirit of the design and look IH Cub had in mind.) https://c7.staticflickr.com/9/8564/2...e90aef22_c.jpg2016-08-04_12-53-19 by yourshoesareuntied, on Flickr Project Album Here https://c3.staticflickr.com/9/8277/2...56a81c57_t.jpg https://flic.kr/s/aHskC461kS |
In my opinion do what you need mechanically, but cosmetically I wouldn't touch it! Ole girl looks great! But it's yours you can do as you wish!
Perfectly restored tractors are great and I enjoy looking at them, but I also like tractors that owners have added there own touch to.
I say make it however you want, its your tractor!!:beerchug: I have a 100 that I want to fix just to putt around shows on, so no lift, or pto. Saved a frame from the scrapper and have welded all the holes up, it will be smooth with no barbs. Randy |
Today I pulled the engine, I found a place that has been well known for small engine machining for decades here. I want to get it mic'ed out so I can get a rebuild kit and properly select the standard rebuild kit or the 10 overbore
50.00 to inspect bore and if needed overbore, can re-sleeve to spec for additional cost . 50.00 for the crankpin I believe if needed they do something to repair it but I don't understand what.. 35.00 valve job. Have any you replaced the the points and condenser with a solid-state ignition module? So far the only ones I find state they are not for battery ignition systems. |
Good luck with your 105!
Thank you J-MECH, been a long time since I took small engine repair in Shop class..
I'll ask about the valve angle and I bet your right on the pricing, its likely the charges if they have to bore or grind.. my understanding is this is where the local repair shops send the K series Kohler. I'll make sure before they take it. |
