-   -   Electrical diagram for an 1872 (https://www.onlycubcadets.net/forum/showthread.php?t=45025)
Steve N Mi 07-14-2016 03:12 AM
I put a new front PTO switch in my 1872 and now I have NOTHING. I looked in the owners manual for a wiring diagram but don't find one. Can someone help?
Thanks for your help, Steve
R Bedell 07-14-2016 06:35 AM
Diagram sent to the E-Mail address listed in your profile.
Steve N Mi 07-14-2016 02:24 PM
Thanks, but my PTO switch is a 5 spade.
New PTO Switch
For Cub Cadet: 725-0893 / 725-0893P / 925-0893
Made by Indak the OEM supplier.
R Bedell 07-14-2016 03:16 PM
Is the switch pictured a 5 terminal switch..?? :Huh:
Steve N Mi 07-14-2016 03:48 PM
Yes, 5 spades. 3 plug into one socket and 2 into another socket.
This is the same physically as the switch I removed.
R Bedell 07-14-2016 03:53 PM
OK....what am I missing...??? I sent you the Wiring Diagram and I assume you checked to see if it wired correctly.
Did you have something before you replaced the switch...??? :Huh:
Steve N Mi 07-14-2016 10:40 PM
Funny, I assumed the correct diagram would display the pin-out matching the OEM switch and mate to the two female plugs on the 1872.
Yes, lights worked, engine started and ran and pto for deck could be made operational by jumpering the two red leads while not plugged in. This is the way I bought it and I have started it a few times w/o jumper. I do think the female brass spades need to be cleaned for better contact and will work on that.
J-Mech 07-14-2016 11:03 PM
It does..... :bigthink:
R Bedell 07-15-2016 06:49 AM
PTO for deck could be made operational by jumpering the two red leads while not plugged in
The two "red" wires have NOTHING to do with the PTO circuit. The red wires are part of the "start" circuit. Normally, the PTO switch has to be in the "off" position, and the brake pedal "Neutral Safety" switch has to be depressed to start the engine. This is clearly indicated in the Wiring Diagram I sent you.
:bigthink:
Tsharood 08-14-2026 02:25 AM
Did this ever get solved I have the same situation
Just checking on what came of this I am in the same situation. Everything was working but PTO switch would kick off sometimes I ended up breaking the switch by taking it apart to clean it and bought the same replacement as op. And now nothing no lights or anything.
