-   -   1863 Hydro Leak (https://www.onlycubcadets.net/forum/showthread.php?t=44762)
Cannon51 06-26-2016 07:11 AM
1863 Hydro Leak
I finally got the 1863 home from my sons house to address the hydro leak. I used it the last few months of last year with it leaking, kept a piece of cardboard under it in his garage. It would leave a bout a 4 inch oil stain on the cardboard every week. I took another mower over there this year and am trying to figure out how to go about this. I had planed to remove the fender pan, pressure wash the whole thing, reinstall the pan, drive it and see where the leak was the fix whatever it was. I'm thinking it is the front seal but a leak can spread oil a lot of different places. Just want to check with you to see if this is the most efficient way to proceed.
Cannon
R Bedell 06-26-2016 07:19 AM
reinstall the pan
Why....???
You can just let the tractor set in Neutral with the engine running and the leak will rear it's ugly head. With the Fender Pan off, it will be easier to see.
:ThumbsUp:
Cannon51 06-26-2016 08:13 AM
Thanks, didn't know if everything was pressurised in neutral. That will be simpler.
Cannon
R Bedell 06-26-2016 09:25 AM
IF......you want to test the Hydro Unit under motion, just jack up the rear end.
:ThumbsUp:
Cannon51 06-26-2016 09:29 AM
All set up for a Sunday after church drive to the car wash. It's nastier than I thought.
Cannon
Sam Mac 06-26-2016 11:25 AM
I've seen worse. What is the knob for on the left, is that the release so that you can push it?
Cannon51 06-26-2016 01:18 PM
Yea, I probably need to take that off. I put the knob back on after removing the cover to move it around in the garage.
Cannon
Cannon51 06-27-2016 05:16 PM
I found the leak. It was where the red pin is. I put a wrench on it and it felt loose. I removed it, cleaned the oring and reinstalled it. I ran the engine and it's not leaking now. I don't even know what this block does but I feel like this was about as lucky as I could have been. Now I need to top off the fluid and put it back together.
Cannon
PaulS 06-27-2016 06:23 PM
Glad you found your leak. There are times one get lucky and it is so simple. One note keep that whole area clean. The heat can disapate much easier.
Oak 06-27-2016 06:48 PM
Good deal Cannon. That is the relief valve for the Hydro-Gear hydro pump.
