-   -   Why is my cam pin leaking oil on pto side? (https://www.onlycubcadets.net/forum/showthread.php?t=44631)
Cubfan79 06-16-2016 09:50 PM
Well the k301 is done being rebuilt, got about 10 min into break in, and I noticed a decent leak out the cam pin on the pto side of engine. What is this caused from?
athomas 06-16-2016 10:16 PM
Possibly not driven in to proper depth below block surface ? Not sure of that # but kohler engine manual references it .
Cubfan79 06-17-2016 06:29 AM
Going to tear it down enough to try tapping in more then:bash2:
Cubfan79 06-18-2016 12:20 PM
Thanks, pin was not in all the way. Tapped in, ran an hour at full throttle on stand. No leak. :High5:
athomas 06-18-2016 09:28 PM
Glad it worked out !!
Cubfan79 06-19-2016 02:19 AM
Yes, thanks for the advice. Now the wiring,,,,,,ugh
Ran on the stand fine, put it in the tractor, fried the ground. Assuming I used to small of gauge wire.
Swapped ground from 123 and my positive wire started smoking :bash2: connection was loose. Will try again tomorrow
