-   -   Throttle (https://www.onlycubcadets.net/forum/showthread.php?t=44323)
Dodge71 05-28-2016 11:42 AM
Throttle
I have a 126 put a new throttle cable on cause old one broke.I took cable bracket off of motor the one with the spring. Off to hook it up bolt had a spacer. Looks to be only one way to do it. And now I have to hold the throttle if I want anything over a idle. Wth
Jeff in Pa 05-28-2016 07:57 PM
If you advance the throttle and it comes back on it's own, you need to tighten the friction slide. ( the bolt where the handle slides )
finsruskw 05-29-2016 09:25 AM
Darn new replacements are a little on the short side.
About 2-3" short. Hard to keep them from contacting the blower housing screwing up the fresh paint job also.
Dodge71 05-29-2016 09:49 AM
OK I'm gonna try it I'll let you know
Dodge71 05-29-2016 11:03 AM
It worked thank you very simple fix was driving me nuts lol
Jeff in Pa 05-29-2016 08:25 PM
Glad to hear it was a simple fix :beerchug:
