1000 throw out bearing - which is correct?
I am rebuilding the clutch on my 1000 and have a question about the throw out bearing.
I am looking at a couple of sources for parts. I see two different throw out bearings. The first is shorter bearing P/N IH-391237-R91 or 941-3056: http://i88.photobucket.com/albums/k1...psevvrsdfv.png The second is longer and has a grease zerk. It is PN/ IH-106386-C91 or 703-0600: http://i88.photobucket.com/albums/k1...psluvbtaz0.png My tractor has a short round section that has a grease zerk on it. Which throw out bearing should I get? I would think that it would be the short one since my clutch already has a zerk on it. I thought I would ask here before I bought parts. |
There is a serial number break for using the longer one, not sure what it is though.
There is a break at Serial Number 612808 .
http://www.onlycubcadets.net/forum/s...&postcount=111 Not sure what parts it affects?:bigthink: How's that?:biggrin2: |
The 612808 serial number breaks apply to items, 8, 27, 28, & 29
The throw out bearing (item #3) is unaffected by the serial number range. This according to: http://www.cubcadet-parts-direct.com/free-parts-search?gclid=CIL8yNDNobUCFVFgMgodj1cABQ#/Cub_Cadet/1000%2c_2050550U%2c_2050540U/Clutch/000800-A/0008000012 |
The exploded view from the link in post #4 has the parts in the wrong order. The service manual has a picture of the parts in their correct order.
Am I correct in thinking that the longer bearing is for later model tractors? |
the longer one is used on the 82 series. my 89 1050 uses the long one.
i converted my 108 over to the longer one, when i bought my new driveshaft from jeff i had him skip that hole and i drilled it for the longer tob.
http://www.onlycubcadets.net/forum/s...ead.php?t=4644 |
I took the clutch out this afternoon and disasembled it. This is what I have:
http://i88.photobucket.com/albums/k1...pst6iem4h3.jpg Yes, I know the throw out lever is incorrect. The original got trashed when my brother kept using the tractor even though the bearing was locked up. Hanger bracket: http://i88.photobucket.com/albums/k1...psuywtpwgx.jpg The hole used to be round: http://i88.photobucket.com/albums/k1...psleof2yb7.jpg I think I'll replace the pivot pin: http://i88.photobucket.com/albums/k1...ps3nxsxc0g.jpg I turned the pressure plates a couple years ago. They still look good: http://i88.photobucket.com/albums/k1...psu8xpqy2y.jpg This doesn't look good: http://i88.photobucket.com/albums/k1...ps9jadf9nc.jpg The disc looks good. It was replaced two years ago: http://i88.photobucket.com/albums/k1...ps6nmaxqfv.jpg Pins out: http://i88.photobucket.com/albums/k1...psivgjppxx.jpg The teaser spring and cup were hanging up. When I stripped the parts off the shaft I found steps in it that were causing the clutch to not fully engage. This explains why the clutch was slipping: http://i88.photobucket.com/albums/k1...psivgjppxx.jpg http://i88.photobucket.com/albums/k1...psidl2ietm.jpg |
