-   -   782 3pt hitch (https://www.onlycubcadets.net/forum/showthread.php?t=42050)
SS5150 12-18-2015 02:39 PM
782 3pt hitch
Question, I have 2 IH 782s, under 720,000 serial#. My question is, can the #389 3pt hitch fit the lower serial # tractors, or will it need to be adapted, or is it a no go all together? I thought the newer mtd 782s had it as an option & I'm trying to figure out if it will work on the older tractors.
I have the IH rear lift on 1 of them already, just wondering if the cat. 0 is doable.
J-Mech 12-18-2015 03:56 PM
Yes. Should bolt right on. Could possibly have to drill a hole in the frame, as I'm not sure that they are already drilled/punched, but it will play. :beerchug:
