-   -   149 moves while cranking (https://www.onlycubcadets.net/forum/showthread.php?t=41924)
switchman 12-07-2015 06:07 PM
hi
I have a 149/hydraulic lift. The neutral is properly adjusted but, when starting, I can hear the hydro is engaged and it starts to move while cranking.
any suggestions?
thank you
switchman
Jeff in Pa 12-07-2015 06:28 PM
Welcome Switchman :beerchug:
Does the lever return to neutral when you step on the brake? It seems like the adjustment may be off.
Here's the link to the Technical section here on OCC for your 149
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Jeff
Sam Mac 12-07-2015 07:45 PM
Originally Posted by switchman (Post 354365)
hi
any suggestions?
thank you
switchman
If it moves while cranking, the hydro is not properly adjusted. Sorry but neutral is neutral, if it moves while in "neutral" some ting be wrong. :beerchug:
Yosemite Sam 12-07-2015 07:53 PM
Welcome to OCC
The lever can be in the "right place" but that doesn't necessarily mean the linkage underneath is adjusted properly.
Here's a link that might help. http://cubfaq.com/neutraladjust.html
