Hydraulic lift speed
the lift on this 1811 seems kinda slow and i was wondering if there's a way to adjust the pressure to speed things up? before someone suggests it i already replace the filter and fluid.
This is assuming you have the correct fluid and filter, you can adjust the "charge pump" relief spring. It is item #2 in the image. It can be shimmed to either add or decrease pressure. The procedure is outlined in numerous Hydro Service Manuals.
thank you Roland, i should have thought of that myself.
You do need the shims though.Where do you get them from?
you did? what did you use?
Oh ,if it is okay to do that.
Did it improve your speed? BTW I do have shims.... |
Pressure has no effect on speed. Only flow. I imagine your pressure was fine and you have another issue.
