682 no reverse
Hello has all after cinqs the years without turning(shooting) my 682 resumed(took back) life having revised the engine and the electric circuit without having the slightest concerns(marigolds) I wanted the tried on the road.
It is that comes my problem in forward gear everything goes very well but that I lower(dim) the lever to move(put) back nothing takes place. Has to note that the oil and the filter are new. Thank you in advance for your reponsses. sorry for languages my english is not very good |
There are two check valves on the hydro unit. One is forward, one is reverse. Switch the check valves and see if the problem now becomes no forward.
Il ya deux clapets anti-retour sur l'unité hydro. L'un est l'avant , on est inverse . Mettez les clapets anti-retour et de voir si le problème devient pas en avant. http://www.onlycubcadets.net/forum/p...pictureid=6630 |
You will find the service manual here:
http://www.onlycubcadets.net/forum/s...ad.php?t=13226 |
Thank you for your help(assistant) I have to exchange of place(square) both valves and the reverse gear walks(works) very well.
Sorry to answer so late |
