Where do you get power steering boxs rebuilt ?
I have 1572 cub with leaking power steering box. I would like to get it fixed
If you can pull the steering column out you can rebuild it for less than $70. It's harder to get the column out of the tractor than to rebuild it.
I just did mine on the 1872. I haven't finished putting the column back in yet to determine if I screwed it up. The only difficult part is getting the springs to stay in place when you put it back together. I would recommend that you also order the spring kit. It's cheap and you'll have backup springs if one goes flying. Just a note, manual says if one spring needs replaced, all of them do. You're going to want to make a fixture tool per the manual. I had one made and it worked perfect.
You may have seen this already and the is a better rebuild on MTF.
http://www.onlycubcadets.net/forum/s...ad.php?t=27895 |
Awesome idea! Hope all has been well your way! :beerchug: |
| All times are GMT -4. The time now is 08:50 AM. |
