-   -   I finally installed the float button on my 125 .... (https://www.onlycubcadets.net/forum/showthread.php?t=40545)
Jeff in Pa 08-23-2015 07:20 PM
and it's amazing how nice the float feature works on my 125 with the 42" cast iron end mower. :beerchug:
Back in '03 when I purchased the 125, the button for the lift handle was missing so I drilled and tapped a piece of 1/2" round bar. That worked for setting it in a notch but since it didn't have the correct cutout plus the push button on the handle itself was broken, no float.
I made the correct handle button ( thank to Lew for the original to copy ) and installed a factory float button in the handle.
http://img.photobucket.com/albums/v7...2.jpg~original
The lawn looks even better now :biggrin2:
olds45512 08-23-2015 07:44 PM
looks good as always Jeff, if i were in need of one what would it cost?
Jeff in Pa 08-23-2015 07:50 PM
Probably around $18. The undercut for the push button latch is a real :censored: to cut.
J-Mech 08-23-2015 08:11 PM
Can you make the little lock button too? The 125 I gave my bro was missing the little button. Would be cool to get him one.....
Jeff in Pa 08-23-2015 08:16 PM
Sheetmetal for the center section. But it is available from the dealer ( around $24 )
edit
Cub Cadet IH-401449-R1
Lock Assy, Release Rod
J-Mech 08-23-2015 08:20 PM
I'll check again on that. I thought I had looked and it wasn't available. :bigthink: Maybe I just assumed. That was a while back.
Nice work as always! :beerchug:
Berwil 08-24-2015 12:00 AM
Nice job Jeff! :beerchug:
I finally made a wire bail to lock float on my O earlier this summer. It's nice when the little jobs make a big difference!
Bill
