Hydro pump
Hello I know where a 149 and a 1650 ported hydro pump is for sale, would they work on my 105 and 1250? :bigthink:
i know that the one off the 1650 will bolt right up to the 1250. You may have to cap the front pump holes off, the other one, i dont know
If the 149 pump wont work for you I would be interested.
If you aren't adding hydraulic lift to either, you'd have to cap the ports and change get a different relief valve spring and plug.
If I get one I am going to add hydro lift.
Then that pretty much limits you to the 1250.
