-   -   Belt size (https://www.onlycubcadets.net/forum/showthread.php?t=39885)
4049Matt 07-12-2015 09:13 PM
Belt size
Cub 125 with 42u deck. There no way an 80" belt is the right length drive belt. With the spring off of the mule drive and the adjuster all thread piece off its unbelievably tight. Drive pulley on deck is smaller then the blade pulley and I can barely get the belt on. Right now I'm boosting the battery trying to use the starter to help.
olds45512 07-12-2015 09:16 PM
looks like it calls for an 81" belt not an 80"
4049Matt 07-12-2015 09:27 PM
Thank you. Somewhere I read it was supposed to use an 80"
_DX3_ 07-12-2015 10:56 PM
Check out Tractor and Implement library for info such as this.
Belt Chart link:
http://home.comcast.net/~dos0711/CCBELTCHART.htm
