982 Rockshaft Replacement
I"m restoring a 982, the rockshaft needs replaced. Can I use a rockshaft out of any cub super?
you can use 982 though to the Cyclops ones with plastic hoods.
The late Cyclops supers have a different rockshaft than the earlier ones.
Is a 2082 or 2084 to new for my 982? Thank You
2084 won't work
2082 if the serial number is under 821000 should work. Check here to see the differences under the impliment lift. http://www.partstree.com/parts/searc...hTerm=cub+2082 |
