-   -   73 Electric Lift (https://www.onlycubcadets.net/forum/showthread.php?t=39512)
sbleich 06-17-2015 11:04 PM
73 Electric Lift
I see that IH offered the electric lift option on the 73. I have a 73 and an electric lift and would like to install it. My question is, where would the switch go? Would IH have made a special dash for the electric lift option? Anyone out there have this option from the factory? Thanks for any help!
Cub Cadet 123 06-17-2015 11:09 PM
There should be a chrome knock out in the upper right hand corner of the dash for the lift switch. That was used for the cig lighter or the electric lift switch.
darkminion_17 06-18-2015 12:11 AM
Pretty sure that the elift was not an option for the 73,even says it in the owners manual,not sure how it would work on the low tunnel frame.
sbleich 06-18-2015 12:27 AM
I have the "50 Years of Cub Cadet" and it lists it as an option. :bigthink:
darkminion_17 06-18-2015 11:17 AM
My 1970 parts and accessories brochure list it only for the 106 107 126 and 127, but the hydro one is,sure you can put it on,but there will be no guard,and your switch will be below the ign switch,there is a chrome knock out there.Not a good spot for it,I can see the knob getting broken off.
Alvy 06-18-2015 12:20 PM
Sometimes these books and illustrations are incorrect. What's wrong with this picture?
Attachment 66173
darkminion_17 06-18-2015 12:35 PM
No Pabst on the picnic table?
olds45512 06-18-2015 01:10 PM
Attachment 66173
Does it say 147?
darkminion_17 06-18-2015 01:24 PM
2 Attachment(s)
yes it does,this one say's it too,and the udder one is a 107.
mattoney 06-18-2015 01:28 PM
Attachment 66173
To answer your question: It was a 149 labeled a 147, and there's no PTO belt going to the mower deck. You can see the pulleys on the mule drive.
I've got the Book "Original Farmall Cub and Cub Cadet" by Kenneth Updike and that 147 appears two or three times. He described it as a test mule in disguise.
