| nkeel8106 |
06-16-2015 10:48 PM |
1863 PTO Problem
Need help with my some PTO issues on my 1863. Yesterday while just starting and moving my tractor out of the garage, I noted that it started hard, almost like the battery was going on it. It did start but I found the PTO engaged and mower was running. I turned the tractor off with the PTO still engaged because nothing I did with the switch would disengage it. I flipped the switch a few times and tried starting again. It started normally without the PTO engaged. Today, I went out to mow the yard. Again it cranked hard and the PTO was engaged when I started it. All the time the "disengage PTO" light is on but the tractor starts anyway. So, I figured I had no time today to look at it further I would just continue to mow since the PTO was on and mower was engaged. I made it about 30 seconds and the PTO stopped on its own. I lowered the throttle and attempted to re-engage the PTO and it worked. I mowed the rest of the yard without issue. After I was completed mowing, I was able to disengage the PTO with the switch. I have never had PTO issues with it before now. Now, I ask for your kindness because I'm not as mechanically smart as I would like to be but I have been around cubs my whole life. Just wondering if this has happened to anyone else and where I should start.... :bigthink: Switch, wiring, PTO?? Thanks in advance!
