-   -   127 Turning Radius question (https://www.onlycubcadets.net/forum/showthread.php?t=3904)
labrati 04-16-2010 11:56 AM
Hello, newbie question... I have a 127 that turns at least 30% sharper when making a left-hand turn vs a right-hand turn.. is this normal?
thanks
Matt G. 04-16-2010 03:52 PM
Most of them are set up that way so you can trim close to trees. If you want it to steer more equally, disconnect the drag link, point the wheels straight ahead, and find where the steering wheel is halfway between the left and right stops. You'll then have to shorten the drag link by threading the rod ends on a bit further until the center-to-center distance between the ends matches the distance from the steering knuckle to the arm on the steering gearbox.
