-   -   Float on a front blade (https://www.onlycubcadets.net/forum/showthread.php?t=38229)
Group_44 04-13-2015 05:30 PM
Is there away to lock out the float when using a Haban front blade on a Cyclops super like a 2084 or 2086? I want some downforce to do some light grading.
Group_44 04-13-2015 07:27 PM
Never mind, I see by the search on the forum locking out the float on a front blade is not recommended.
Tankman 04-14-2015 09:05 AM
On my manual lift tractors I can apply pressure down holding the lift arm, apply pressure.
Don't know if you can do so with the hydro. Perhaps add weights to the plow / dozer blade? You did say light grading.
My long gravel drives need grading and rolling and I also use a plate tamper. :beerchug:
https://youtu.be/lalmNq3d-KI
jimbob200521 04-14-2015 09:08 AM
If you need light down pressure, your best bet it to add a small amount of weight to the blade itself as tankman said. Otherwise, like you've read, using the lift rod to apply down pressure will result in a bent lift rod; ask me how I know :biggrin2:
