| clintsinger |
04-12-2015 09:21 AM |
Originally Posted by mv7fd
(Post 322006)
I rebuilt the carb on my 1000 and when I went to mount the carb back on I noticed the gasket was a thick gasket but the one I have is all messed up so I need a new one would everything work fine if I put a thin gasket on or even silicone it back on
If you are going to use something on the gasket RTV silicone is not a great choice, as it does not stand up to fuel etc, when the silicone dissolves it can leave the carb loose and cause all sorts of issues with running. I use here at the shop a good grade of gasket maker, that specifies on the package that it is good for fuel and oil, also use very little just a smear with the tip of your finger is all that is needed and you will be fine, shorter bolts as posted is a good idea.
all the advice posted can be put together and digested and you won't go wrong.
