-   -   Cyclops lift control valves (https://www.onlycubcadets.net/forum/showthread.php?t=37573)
gt383mag 03-09-2015 11:40 AM
my brother has a 1863 we are going to make into a 1864 by adding power steering. we would also like to have 2 hydraulic valves for angle blade and such. am i correct that the valves are stackable? has anyone made lines with those kinds of fittings successfully? or what models came with the double valve setup if any that i might be able to look for lines from oem if any are available?thanks guys
Shrewcub 03-09-2015 01:00 PM
The double valves were optional on all hydro-lift cyclops. It was a rare option from what I have seen. Sam had the fittings to stack them made. I think a good hydraulic shop could make the lines/fittings.
gt383mag 03-09-2015 01:23 PM
thanks shrew im sure sam will chime in soon enuff...
gt383mag 03-09-2015 03:03 PM
is there room enuff in the dash for three? not sure we need that many but i guess if we are in there and theres enuff room who knows... i can send you a check sam
V30crewcab 03-09-2015 10:46 PM
I think theres holes stamped in for 3 valves already.
jimbob200521 03-10-2015 08:18 AM
Here is a thread I have bookmarked from this site as I am going to do the same thing this spring, add a 2nd valve to my 1864. There's some good reading material in there :beerchug:
http://www.onlycubcadets.net/forum/s...t=28750&page=4
Dave01 03-10-2015 10:02 PM
I added a 2nd valve to my 2084 to run front hydraulics. I bought a used kit from one of the parts vendors, wasn't too expensive and had all fittings and brackets. They stack easily, just have to extend the slot in the dash for the 2nd control handle.
Sam Mac 03-11-2015 08:18 AM
Yep I have the adapters that go between the valves when you stack them.
This is the pricing for the valve adapters
Valve adapters are $7.00 ea
Shipping is $3.00 for 1-3
This is what they look like.
jimbob200521 03-11-2015 09:28 AM
I don't suppose you have any under-dash pics of the install? I'm curious how hoses are routed as well as the valve mounted/attached. :bigthink:
Dave01 03-11-2015 09:42 AM
I don't, and am not near the tractor right now, sorry. The valve mounting is very obvious, just attaches to the existing valve and the lever location is directly above the existing dash lever, you just extend the rectangular cutout in the dash. Hose routing is just the easiest path that doesn't come in contact with any moving parts, was very easy. This is for adding front outlets, not sure of the challenges of adding power steering.
