-   -   Refinishing plastic hood and side panels (https://www.onlycubcadets.net/forum/showthread.php?t=37313)
Redneck #1 02-20-2015 10:02 PM
I bought a 1862. I would like to refinish the hood and side panels which are cream colored plastic or fiberglass. Any ideas what is the best approach to this? I thought about 0000 steel wool or maybe fine wet/dry sanding paper.
Or should I just get it clean and repaint it?
Thanks for any direction in this project. :bigthink:
64fleetside 02-21-2015 08:36 AM
I'd use a gray Scotchbrite pad, 3M #07448. Add some flexibilizer if you are spraying it.
EDIT-Sorry I thought you meant you were painting it. Still on first week w/o coffee...
bugeye 02-21-2015 10:00 AM
Unless your intent is to paint, sanding with steel wool will add scratches. I polished mine with Mcguire's PlastiX. This product is available at automotive stores like Advance Auto, Pep Boys, etc. It is a polish intended for plastic, like headlights. If you have a dual action buffer, DA, use a soft foam polishing pad. Careful not to heat the plastic too much. when polishing.
yeeter 02-21-2015 10:43 AM
I would try polishing first. On amazon you can find headlight polishing kits that work through a series of abrasive paste.
Then if you didnt like how it polished out, scuff it with 220 grit and paint.
Mike McKown 02-21-2015 02:00 PM
What follows is FREE! That's what it is worth so proceed at your own risk.
I have very limited experience shining this plastic after it's been weathered.
I do know that sanding it will put scratches on it. Almost like the plastic balls up.
I believe I would try as suggested above, the headlight polishing method first.
One thing I did try briefly and only on a sample piece, I sprayed non-chlorinated brake cleaner and quickly wiped it off before it dried. If left a dull and weathered surface slick and shiny. But, it will also streak if you can't do it evenly.
I haven't tried to paint the stuff yet.
Proceed at your own risk.
