-   Customized Cub Cadets (https://www.onlycubcadets.net/forum/forumdisplay.php?f=11)
-   -   147 hydro pump reversal for CCW shaft rotation? (https://www.onlycubcadets.net/forum/showthread.php?t=36750)
redneckarchery 01-18-2015 12:41 AM
Is there anyone on here who has swapped the charge input around and used a different engine on a hydro? thanks
J-Mech 01-18-2015 09:51 AM
Don't do it.
What motor would you use that turns opposite anyway?
cubs-n-bxrs 01-18-2015 10:37 AM
Jon read some of his older posts and it will be clear to you.:bigthink:
J-Mech 01-18-2015 11:08 AM
redneckarchery: You already asked this question in this thread:
http://www.onlycubcadets.net/forum/s...ad.php?t=36659
Doing this is not a great idea. If you can't find an engine, put an ad in the wanted section. I know you live in Florida where Cubs aren't as easy to find as they are in other parts of the country, but surely someone would find and ship you one. FWIW, where is the original motor? Can it be salvaged? :bigthink:
redneckarchery 01-18-2015 05:13 PM
hey
Look there are several people who have done it thats why I was asking. I didnt post to get a
mocking of the conversation and topic. Maybe I dont want the Kohler in there? I am just looking for options thats all. I have 2 Kubota Diesel engines a Lombardini and small gas engine. Dont worry about.
redneckarchery 01-18-2015 05:23 PM
If I decide to put an engine in they runs ccw( oposite of the Kohler)
I was told that
1. I could flip the input of the hydro around 180 degrees and make it compatible.
2. Someone on here sell an adapter for the Predator engine
I posted in another section and didnt really get an answer , instead it was the
DONT USE NOTHING BUT A KOHLER crowd.
J-Mech 01-18-2015 05:24 PM
So do what they did.
Take the charge pump off and rotate it 180°.
Take the ring gear out and flip it to the opposite side.
And that's what you got. Not our fault you don't like them. :bash2:
J-Mech 01-18-2015 05:29 PM
Ok, listen up. You have 3 threads started all asking the same question. 2 of which are in the same section. I'm going to put two of them together.
J-Mech 01-18-2015 05:36 PM
Nope.
Just so everyone is on the same page and not asking a bunch of questions.
Yosemite Sam 01-18-2015 08:30 PM
IIRC, I believe that "Only Cub Cadets" is the self acclaimed, "Friendliest Cub Cadet Site On The Net". If that is the case, WHAT THE CRAP IS GOING ON HERE???
I agree that Cubs came with a Kohler for a reason... I also agree that when we get a chance, we should help to guide someone who seems to have lost their way. I DON'T believe that anyone should be bullied!
The OP asked how to change direction of the pump and on multiple occasions has expressed his desire to use a different engine.
You don't have to agree with what he wants to do, but I think he deserves to have his question answered in a friendly mannor.
It is my contention that if you can help to answer his questions, then by all means answer them, otherwise get off the guys a$$ and leave him alone.
Am I correct in thinking that if you rotate the charge pump, it only reverses the direction of the "needed input" and doesn't reverse the direction of the output?
So, if you rotate the charge pump AND flip the ring gear... It will go backward with the lever in the forward position. Is that correct?
