2182 fuel shut off valves
I'm posting this to hopefully help others. I tried to buy replacement fuel shutoff valves for my 2182 and was told they were no longer available. I found these from another model and they should work for a replacement. Hopefully this helps someone.
http://i1073.photobucket.com/albums/...F552085DD4.jpg |
They look the same except for the screen. What are they supposed to go to? Were yours so bad that you couldn't clean them?
Not bad for 11.00.nice find.
Better for $9.21
Displaying search results for '951-0171' in Cub Cadet Part # Outdated Description Price Where Used 1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21 751-3007 ! USE 951-0171 VALVE-SHUT OFF $9.21 951-0171 VALVE-SHUT OFF $9.21 GW-1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21 GW-1751477 ! USE 951-0171 VALVE-SHUT OFF $9.21 GW-B1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21 IH-135354-C1 ! USE 951-0171 VALVE-SHUT OFF $9.21 |
I'm not sure what model they are from. I just bought them just incase mine started to leak after cleaning them and actually using them. My 2182 has sat outside for some time before I got it and they didn't look good but wound up cleaning up fine. Can't hurt to have spairs just incase. I paid $11.91
That looks exactly like the one installed on my 782D...screen and knob look identical...thanks for sharing the info
Kinda looks like the push/pull valve off a quiet line would also work.
