3 point question
I need info on how to remove mower deck on the 129 and installed the lift bar for the 3 point.
Best bet is to go to the Technical library sections and download the user manuals for your tractor and your mower deck.
Deck removal involves pulling the support pins at the rear edge of the deck, that drops the rear of the deck from the support frame. Slide the deck forward and the front will drop off the support frame. Remove the belt by releasing the PTO operating lever, and pulling the belt out. Reinstall the PTO lever linkage. Release the mule drive from the front of the tractor by pushing the latching bail,then pull the mule drive off. Remove the deck support frame by pulling the pair of hairpins that hold the frame to the lift rockshaft arms. pull the frame out. Its quite simple, just a little hard to explain., You need to get down on your knees and figure it out. Installing the lift is a little more involved. Again, there are instructions in the user/chassis manual. Do you have all the parts for the rear 3 pt. lift? The lift actuator bar runs inside the frame from the lift casting at the rear to the rockshaft. check out this thread: http://www.onlycubcadets.net/forum/s...highlight=lift |
Thanks, Now I can finish the install tomorrow.
