-   -   Hydraulic lever Play (https://www.onlycubcadets.net/forum/showthread.php?t=35235)
Steve149 10-16-2014 03:34 PM
Quick question on this lever...how much play is supposed to be in it? Mine moves quite a lot in either direction before engaging the valve to raise or lower implements and is there an adjustment for this???
Thanks Guys!!!
:beerchug:
J-Mech 10-16-2014 03:38 PM
What tractor are you working on?
Steve149 10-16-2014 03:42 PM
Sorry the 149!!!!
R Bedell 10-16-2014 03:50 PM
Something wrong with your Hydro Linkage.:ThumbsUp:
Steve149 10-16-2014 03:55 PM
Yes I assumed this much, but is there supposed to be any slop in the lever or not? if so how much and is there something that needs adjusted? I don't know that is why I asked!!! I have to tear the gas tank off to fix another issue and was thinking of killing two birds with one stone whilst in there!!!
R Bedell 10-16-2014 03:58 PM
NO..........
J-Mech 10-16-2014 04:01 PM
Nope, no play. Take the tank off and look at it. Should be self explanatory when you look at it. Very simple set up.
Steve149 10-16-2014 04:03 PM
Thanks Jon...:beerchug:
TheSaturnV 10-16-2014 04:08 PM
Also consider the friction disk down inside the dash tower. If it has loosened up enough, this will add to the floppy feeling given off by out-of-adjustment linkages.
:American Flag 1:
Steve149 10-16-2014 04:15 PM
Jon on a side note the guy is rebuilding my lift cylinder for 100 bucks. He said since this if for an old Cub Cadet kudos for restoring a good thing! I thought that was cool! I wish EVERYONE had that good nature about them!!!
