-   -   Idle down or boom (https://www.onlycubcadets.net/forum/showthread.php?t=34741)
garnold 09-19-2014 09:36 PM
Idle down or boom
My uncle had explained to me that our older kohler engines need to be idled down before run down or run the risk of backfire. Anyone tips to prevent this or is this just the nature of the beast?
olds45512 09-19-2014 09:40 PM
I always idle all my cubs to prevent backfire, 30 seconds is plenty.
drglinski 09-19-2014 09:53 PM
I've always idled mine down too. Even with an idle down Dad's 125 used to backfire after shutting off. We got used to shutting it off and immediately covering our ears. Even on my 147 sometimes I still do it.
J-Mech 09-19-2014 11:46 PM
ALL engines should be idled down for a while after running. Just like you don't like to just collapse at the end of a hard run, your motor doesn't like to be shut down without a cool down. I even let my vehicles idle for a little while if they have been running hard. (Like when I'm pulling a trailer, or they have been on the interstate running hard.)
The backfire is a result of fuel entering a muffler that is hot enough to ignite it. Sometimes it is indicative of an engine that needs some attention. Too rich of a fuel mixture. Or even too lean, causing excessive heat. Lots of reasons. Most of the time it can be fixed, but just letting them idle may be all they need.
If yours doesn't backfire, great!! But you should still be in the habit of letting it cool down. Your uncle is correct. Sometimes, the simple answer is just hat. LET THEM COOL! :beerchug:
FWIW, this topic gets beat to death on here every few months.
gdheck 09-20-2014 02:17 AM
I always idle mine for a while and don't have a problem, but my dad forgets to once in a while since my cubs have the only older Kohlers he's used. If we're lucky, someone is walking by on the street and it scares the crap out of them. :biggrin2:
I don't know if there is a difference because of the different mufflers, but my narrow frames seem to backfire and the quietlines don't. Of coarse, my mag 20 likes to backfire once in while when I re-start it right after being shut off.
cubby102 09-20-2014 04:45 AM
With mine I always ill it for a few seconds at minimum just to let em ease into it. But more times then not I just the fuel off and let the carb run out at idle . Just a old h abbit from my quad days
jeepchicken5000 09-20-2014 07:50 AM
ive very rarely had backfire on my cubs, I did start my 102 in the garage the other day and with the door open man it sounded just like a cannon shot. I bet people enjoyed that :biggrin2:. I always idle my 102 down for a minute or so then take it and either wash it or use an air hose and blow it all down. I remember my father doing it with his 123 and now that's what I do. is it me or are the old ones a lot easier to clean because they don't have as many shields, I cant remember blowing the engine out on my 682 cause it sucked to get to haha.
Merk 09-20-2014 08:13 AM
Same here
:Cub2:
finsruskw 09-20-2014 08:34 AM
Even when I do idle it down, I still always stand there w/hands in the air and holler "I give up.....Don't shoot".......................
Sadly though, it don't always work!!!!
rfrank 09-20-2014 04:04 PM
Somewhere I read in a manual, when shutting off the kohlers with compression releases, to always turn the key off and go to full throttle. Since I've done that I've never had a backfire. My son was riding it and didn't do that it it backfired and I laughed as he jumped. So turn the key off and push to full throttle and no backfire, works for me on my 149.
