Original 3-point hitch?
I found a 3-point for our Original from one of the great members here. I'm now in search of the Brinley sleeve hitch adaptor. I found one off of a 70 and was wondering if it will fit. Does anyone know for sure if it will fit? Here is a pic of it. Thank you!
http://i1073.photobucket.com/albums/...FDDACB4C5A.jpg |
That one will work , but here is what most O's i have seen had on them ..
They will both work. The latter pic is just an older version (and less robust) of the same thing.
FWIW, there are at least 2 members here who make them. JeffinPa, and Yosemite Sam. |
I call the one that Darrell posted "Sleeve Hitch Adapter Generation I" I guess you would call it "correct for an Original", although I don't know that anyone anywhere would ever suggest that the one you posted isn't "correct".
The one that you pictured is the most common and more readily available. The ones that I build are a little bit of "overkill" for an Original (although, now that I think about it, I have one on one of my Originals). |
I just sold a nicer brinly adapter with lift straps to a member for $90 shipped.
| All times are GMT -4. The time now is 12:17 AM. |
