-   -   Cub "O" Serial # Verification (https://www.onlycubcadets.net/forum/showthread.php?t=33651)
cnixon 07-29-2014 08:47 PM
5 Attachment(s)
Painted looks just like 3 digits 568. Removed paint and I think I'm seeing a 5568. I rubbed some chalk over it to try and bring the numbers out. Looking for some input.
Attachment 54760Attachment 54761
Attachment 54762Attachment 54763
Attachment 54764
J-Mech 07-29-2014 09:45 PM
Hole in the frame for a creeper vent. Pretty sure it isn't a 3 digit. 4 digit I can believe. :bigthink:
darkminion_17 07-29-2014 10:01 PM
It looks like 568 to me. It must have had a creeper at one time, or they changed out the frame as it probably cracked and was replaced.
cnixon 07-29-2014 10:01 PM
Creeper hole is cut not factory.
cnixon 07-29-2014 10:03 PM
musta had a creeper at one time,or they changed out the frame as it prolly cracked and was replaced
Did have creeper. Took it out.
darkminion_17 07-29-2014 10:05 PM
still though it prolly is 568 as the other "5" is not the same type used on the other "5"
ACecil 07-29-2014 10:15 PM
Looks like it has the thin front axle.
Alvy 07-29-2014 10:17 PM
Agreed, looks like 568 to me. My four digit is close to 10k in serial and has no hole on top either. Very cool to see that axle. What's on bottom right of steer tower? Hour meter? It's looking like you got a very early one, WOW, awesome. Love seeing the differences in this model as the serial progression happens.
cnixon 07-29-2014 10:18 PM
Yes thin front axle, collar spindles, heavy hood, thin spaced rims and no hole in dash tower where your tail light wire runs through.
cnixon 07-29-2014 10:21 PM
Originally Posted by Alvy (Post 277686)
Agreed, looks like 568 to me. What's on bottom right of steer tower? Hour meter? It's looking like you got a very early one, WOW, awesome
Just a big sloppy hole which is on both sides that someone cut to adjust steering column.
