-   -   782 won't go (https://www.onlycubcadets.net/forum/showthread.php?t=33551)
yeeter 07-26-2014 02:59 PM
782 won't go
I have a 782 (new to me). When I push the hydro lever to forward .... nothing. Pull to reverse... nothing.
Another time I started it and pushed it all the way forward and it went (pretty fast, not slowest speed). Then another time I pushed all the way forward, it paused a few seconds, then made a screeching sound and took off.
Pulled the fender and the hydro linkage appears to be working as it should. The trunion is not worn at all (first one I have had that didn't have the trunion worn).
I took the tunnel cover off the the drive shaft is spinning.
While the fenders were off I pulled the top off the rear end and its plenty of hydro fluid (not horribly dirty).
Lift doesn't work either.
Could a filter clog and do this? (filter looks old).
I do have a spare hydro, but wasn't planning on using it for this one (just gave one away as well, dang, maybe should have kept it). A bad hydro seems to be a rare occurrence. Whats next to try?? (Filter I know but I don't have one, maybe time to go get some....)
But most likely the experts here will sort it out quickly.
Billy-O 07-26-2014 03:10 PM
Me thinks your issue is an air leak draining hydro fluid out of the lines. Is why after some time your tractor shoots off after you engage the hydro.
R Bedell 07-26-2014 03:40 PM
Change the Hydro Fluid and Filter.
yeeter 07-26-2014 04:00 PM
I knew this would be at least part of the recommendation - in the works. (do not pass go, do not collect $200 - at least not until fluid/filter change).
An air leak is a new one - an air leak where?
RChristensen 07-26-2014 04:14 PM
Here is a long shot to check out but worth checking. Make sure the rear pin is good on the flex coupler to the hydro shaft. If a pin shears off the drive shaft will be turning but the hydro may not at times and may turn at times.
R Bedell 07-26-2014 04:16 PM
The pump will self prime.
While you have the rear end opened up, here is a real good opportunity to clean it up. Get a new cover gasket and then install you new Hydro Fluid and Hydro Filter.
SS5150 07-26-2014 11:14 PM
I agree with the guy above-sounds like a driveshaft pin wore through or broke.
J-Mech 07-26-2014 11:24 PM
I say fluid and filter. If that doesn't fix it, come back.
cubby102 07-27-2014 03:57 AM
Im guessing fluid and filter as well. Had a 129 that would do this as well as randomly stop moving and it had a clogged filter
yeeter 07-27-2014 06:55 AM
So far in the pool we have:
Fluid/filter
Drive pin sheared
Other
Put your bets in, we will know which of these three a little later this morning... (oh, the suspense!!)
:coffee:
