-   -   Wanted: #26 carb for a 1250 (https://www.onlycubcadets.net/forum/showthread.php?t=33374)
OldCubby 07-18-2014 10:00 PM
The head on my main throttle shaft busted off leaving the threaded part in the main shaft. :angry::bash2: So, I need some help. Either a carb or the main throttle shaft with butterfly and screws.
Thanks.
rick57 07-21-2014 01:28 PM
carb
If you have a part number for the carb I might be able to help you out
Rick
J-Mech 07-21-2014 01:55 PM
Rick
Why do you need a part number for a #26 carb?
Sam Mac 07-21-2014 04:34 PM
Why can't you just drill out the broken screw and re-tap the shaft?
J-Mech 07-21-2014 04:38 PM
Just for reference you can. If it is the butterfly screw he's talking about.
Here's the reference part. They are a #3-48 screw. Nobody keeps them. I have a box that I ordered from McMaster Carr. Brass screw. Also had to order a tap from them as it's so small nobody keeps a tap. Not even my local machine shop had one smaller than a #4. They are brass screws and drill easy...... if they're original. :beerchug:
rick57 07-23-2014 01:32 PM
Because his ad said "Wanted Carb" so if he wants a new one I would need the part number.
Rdrnek 08-04-2014 11:52 PM
You sound like the guys at the small engine shop I go to to buy Kohler parts.
whats a #26 carb?? it has a 26 stamped in the throat of the carb. If it has that you should be in business.
