-   -   Funky multimeter readings (https://www.onlycubcadets.net/forum/showthread.php?t=32955)
dagenham 06-30-2014 10:50 PM
I wanted to check the battery voltage with my 127 running, but when I get my digital multimeter within a foot of the tractor the meter goes wacky and it just has numbers all over. I cant use it to get a reading, like there is an electrical field around the the engine.
Could it be something from the s/g???
Maxwelhse 06-30-2014 11:00 PM
My digital will sometimes bounce around in the .01 place from, presumably, stuff in the air (on the 20v scale that is). Is it bouncing around more than that? If so, I think your meter is torched.
J-Mech 06-30-2014 11:40 PM
Did you touch the battery with it?
Berwil 06-30-2014 11:54 PM
I haven't had an issue with my craftsman meter measuring voltage on a running tractor. Did you try it on something away from the tractor, like a wall socket? I've had them go bonkers when the internal fuse blows. Problem is you need a working meter to check the fuse. :bigeyes:
Bill
R Bedell 07-01-2014 06:49 AM
It maybe EMI and the better digital meters shield against it. I have no problems with my Fluke.
Shrewcub 07-01-2014 09:40 AM
I haven't used my Fluke on my 102 yet, but when I had my DSR jump box hooked up to it while running the voltmeter in it was acting a little funny. EMI is my guess, I am sure it has a good suppression wire on it :biggrin2:. I will try the Fluke this weekend out of curiosity.
olds45512 07-01-2014 10:14 AM
We have a multi meter at work that is always jumping around until you touch it to something, its kinda annoying but works.
jimbob200521 07-01-2014 11:32 AM
Are you on the right setting? I've never had that problem with any multimeter I've used for voltage checking.
dagenham 07-01-2014 10:52 PM
The meter works fine, I have checked a car battery just a couple weeks ago and it worked fine. I tried a while back and thought the battery in the meter was going bad so I put a new battery in it and still got the same results.
I tried a couple different VDC settings and got the same readings everytime.
It would just start showing random numbers.
Maxwelhse 07-01-2014 11:08 PM
If those random numbers are all over the scale, then I would be concerned... Like I said, mine picks up EMI but its usually in the .01 or smaller decimal. I have a middle-of-the-road Craftsman and I'm sure its not as isolated as much more expensive meters.
