Muffler blues
4 Attachment(s)
The muffler developed a leak so I took it all apart and found out the aluminum muffler box support has a crack in it too. Any ideas on fixing this?
Attachment 53321 Attachment 53322 Attachment 53323 Attachment 53324 |
You have a TIG welder nearby? I recall seeing a low heat ( propane ) "brazing" type repair for aluminum boats. There is also aluminum epoxy on ebay for about $15 shipped too.
My 1450 muffler cracked there too. I wire wheeled it and mig'd it, it's too dirty for tig. Use a higher heat setting and spot welds...zaap, wait a few sec move over 1/4", zaap again. It's been 1 1/2 years and no issues.
Tig will be the easiest on the muffler box. I would still be worried about recracking, may want to plate it and/or add a muffler brace. I made one for mine 2 weeks ago, but am too embarrassed to show it. Bill |
I would say mig the muffler after drilling small holes at each end of the crack and have someone tig the box or aluminum mig spool gun but TIG is best.
6 Attachment(s)
Attachment 53839 Attachment 53840 Attachment 53841 Attachment 53842 Attachment 53843 Attachment 53844 |
Nice work Keith! If it works well, I'd leave it! :beerchug:
Bcdsfcret
Clean the joint up with a wire wheel on a 4" grinder then braze the crack up>
Brian |
(and some other stuff because my message is too short) |
Great job! :beerchug:
Great job! I agree, no sense in pulling it all apart if your plating fix works. :beerchug:
Bill |
| All times are GMT -4. The time now is 08:05 AM. |
