-   -   1860 implement lift handle removal (https://www.onlycubcadets.net/forum/showthread.php?t=32777)
Mike McKown 06-23-2014 09:29 AM
Looks like if I drive #7 roll pin out, the emplement lift handle will just pull off as an assembly?
http://www.partstree.com/parts/?lc=c...&dn=0030400024
RR1862CC 06-23-2014 12:58 PM
That is correct but if it is rusted to the shaft be prepared to persuade it a little.
Mike McKown 06-23-2014 03:11 PM
Thanks. Turned out to be a piece of cake coming off. Both of them. I swapped between two tractors.
RR1862CC 06-23-2014 03:58 PM
Yours was easier than mine. I ended up wedging a gear puller behind it then using my biggest persuader and a wooden block to drive it off. I hope the other one is easier.
