| jimbob200521 |
04-23-2014 10:39 AM |
Originally Posted by daturbosix
(Post 256752)
im not afraid of cutting the frame if needed to get it in there.
but, let me ask this is it possible to adapt the clutch assembly used on a 128 to a command engine?
could you convert a 128 from a mechanical pto to the newer electric pto?
This would be the easy part of the conversion. The Command would HAVE to have an electric PTO, so all you'd really have to do for that is install a switch in the dash and wire it up.
I'll leave the clutch part to the more experienced. I think, as long as the engine and transmission line up, all you should have to do is fab up a coupler assembly to hook the engine up to the clutch. Then again, the Command may sit too far forward or too far back for it to work out but again, others will chime in.
If you've got a welder and a grinder, just about anything is possible :biggrin2:
