Bonehead mistakes!!!!!!!!
Folks I have accidently deleted the photos I took of the wiring at teardown from my phone.I need to know which one of these wires is the positive and which one is the negative.I have a wiring diagram but all it shows is the positive and negative wires,not which ones are which.I figured I could take a battery and quickly hook up the wires and find out that way but my luck as soon as I touch the wrong wires it would ruin the clutch.Hope that makes sense.Thanks.
use a multi-meter and shoot the wires..determine continuity. If you need a talk-on how to do that let someone know and one of us can talk you through that.
Never mind,I got it figured out.I tried to delete the post but couldn't figure that one out.Happy Easter to everyone.
It doesn't matter on a clutch.
Happy Easter |
Pick coils !
:banned: Like Sam the Man says ; don't care situation, +/- . The coil is a set tight wound insolated wires that when current (volts) run through them ,they create a force field that causes a magnet to jump forward , engaging pulley to spin belt ! but careful with other devices +/- is important . Mr bender has always been the go to guy in electrical matters also !!:bigthink:
| All times are GMT -4. The time now is 06:10 PM. |
