-   -   3 point lift pin. (https://www.onlycubcadets.net/forum/showthread.php?t=31323)
OffTime 04-17-2014 05:34 AM
3 point lift pin.
I am installing a 3 point lift system to my 129 and I just purchased a 1a tiller to go with it. I also want to add a sleeve hitch sometime in the future. I am missing the 1" lift pin that goes in the rock shaft. I understand that there is a difference between the pin used for the tillers and the one used for the sleeve hitch. Can anyone tell me what the difference is and what the exact measurement might be on both pins? I'm thinking that maybe I could make one pin that had all holes necessary for both applications. I am a mechanic/fabricator, and I think I have the 1" stock to make the pin easy and cheap, but I need dimensions. Any and all help appreciated. Thank you.
Sam Mac 04-17-2014 07:30 AM
Jeff sells them
http://www.onlycubcadets.net/forum/s...039#post252039
Sugarmaker 04-17-2014 10:20 AM
Yes I just ordered mine from Jeff. I know they would not be too hard to make with the right tools. I do have dimensions here some where. I have a original pin with only one hole on my 147R.
Jeff's pin has two attachment holes. Haven't found which hole is for the tiller I assume the one closest to the tractor?
Regards,
Chris
