-   -   Cub 149 F/R lever adjustment (https://www.onlycubcadets.net/forum/showthread.php?t=31024)
Mr Bob 04-03-2014 04:10 PM
My forward reverse lever will not fully return to neutral after applying brake. Have done a search but could not come up with anything that I could understand. Tractor moves great in forward and reverse and I do not want to mess this up. Any one that can give me some simple adjusting instructions will be appreciated. Forgot to mention that I have the shop manual but still can't figure it out. Thanks in advance for your help. Also forgot to say that it creeps forward after applying and releasing brake.
Bob
_DX3_ 04-03-2014 07:02 PM
It's much easier to do the adjustment by removing the whole rear fender section and tunnel cover. It's actually pretty simple. This link should help. Also it is probably time to check the trunion and see if it is wore. If so now is the time to get it welded up and fixed.
Links:
http://cubfaq.com/neutraladjust.html
http://cubfaq.com/trunionrepair.html
Mr Bob 04-04-2014 01:44 PM
149 creeping
Thank you DX3 for your advise and posting of the links. After viewing the links I have a little understanding of how to go about it. Will give it a try hopefully over the week end. Have a great day.
Bob
